xj6 vs er6
3 posters
xj6 vs er6
bro taj....kasi komen ckit....tgk dalam youtube, top speed tak beza sangat pon cuma pick up je.....bukan bro taj baru angkat xj6 ke....nmpk dalam youtube....
sniper0900- Posts : 23
Re: xj6 vs er6
xj6 rasa ringan..tak vibrate sgt...bunyi yg berbeza...top taj jauh tapi kena ingat er6 650..xj6 600...lebih kepada feel enjin dan bunyi...lain woo..
Re: xj6 vs er6
tahniah bro taj....dah upgrade ke geng2 SBK....update la nanti performance n top speed....wat video....teringin gak nak pakai tapi byk sangat la hutang skrg....
Re: xj6 vs er6
XJ6 2012 spec
Engine and transmission
Displacement: 600.00 ccm (36.61 cubic inches)
Engine type: In-line four, four-stroke
Power: 76.44 HP (55.8 kW)) @ 10000 RPM
Torque: 59.70 Nm (6.1 kgf-m or 44.0 ft.lbs) @ 6100 RPM
Compression: 12.2:1
Bore x stroke: 65.5 x 44.5 mm (2.6 x 1.8 inches)
Valves per cylinder: 4
Fuel system: Injection
Fuel control: DOHC
Ignition: TCI
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 6-speed
Transmission type,
final drive: Chain
Clutch: Wet, Multiple Disc
Emission details: Three-way catalyser with O2 sensor
er6f spec
Displacement: 649.00 ccm (39.60 cubic inches)
Engine type: Twin, four-stroke
Power: 71.07 HP (51.9 kW)) @ 8500 RPM
Torque: 66.00 Nm (6.7 kgf-m or 48.7 ft.lbs) @ 7000 RPM
Compression: 11.3:1
Bore x stroke: 83.0 x 60.0 mm (3.3 x 2.4 inches)
Fuel system: Injection. Digital fuel injection with two 38mm Keihin throttle bodies
Fuel control: DOHC
Ignition: Digital CDI
Lubrication system: Forced lubrication, semi-dry sump
Gearbox: 6-speed
Transmission type,
final drive: Chain
Clutch: Wet multi-disc, manual
gear 3 er6f makan asap la jawabnya.....
Compression: 12.2:1
Fuel control: DOHC
Ignition: TCI
Gearbox: 6-speed
Transmission type,
final drive: Chain
er6f spec
Compression: 11.3:1
Fuel control: DOHC
Gearbox: 6-speed
Transmission type,
final drive: Chain
Re: xj6 vs er6
test ekzos aftermarket ke bro taj.....mcm GP style edition design dia....
Re: xj6 vs er6
lor...tetinggal keretapi rupanya member aku ni...huhuh..kalau 2 inline takkan orang terkejar2 heheh
