Draining the coolant
Page 1 of 1 • Share •
I've bought a bottle of Yamaha Coolant and at the back, it asked me to drain the current coolant off the tank, how should i do that? Do I place a lot of water to flush it out? Or is there something below that can drain it out?
Would appreciate if i can get an answer for that =)
Thanks a lot!
Regards,
Kevin
Thanks a lot!
Regards,
Kevin
kevinpunya- Posts: 9
Re: Draining the coolant
use tube pipe...
buana07- Posts: 420
to like suck the water out? there isn't any cover to remove the coolant below right? =D
thanks for ur advice! =D
yup suck it out he he he...
buana07- Posts: 420
haha alright! i'l suck some out hope i won't swallow it then kakaka
if not i'll be cooler with the coolant =D
thanks for ur help =)
why do we have to drain the current coolant? I never do that. I just add extra coolant oil to the current oil when it already indicate low coolant oil. Is that safe?
ryl_fan- Posts: 11
once 20,000km must be change to new coolant... read manual owner instruction
buana07- Posts: 420
up to certain mileage....u should change the coolant that why u have to drain all inside the radiator system include in reserve tank coolant add in a new liquid for better usage...btw please read user manual
i've read the manual many times and i didn't notice any part of draining the coolant out or saw any guides to drain out the coolant, maybe i'm referring the wrong manual keke
» penjagaan rantai...
» as salam kenal2
» Headlamp FZ8
» SHELL RIMULA R3X RM75 5 LITER
» Salam dari kuching, Sarawak
» YAMAHA TANK PAD RM85
» Berapa harga kalau nak tuka paint Fz ?
» ZAPTOR VOLT STABILIZER RM90
