July 2018
2345678
9101112131415
16171819202122
23242526272829
3031
INDEX HYBRID 3 RM220
Page 1 of 3 1, 2, 3  Next
Post by taj on Wed Oct 21, 2009 11:27 am
Re: INDEX HYBRID 3 RM220
Post by Ristoe on Sat Oct 24, 2009 8:11 pm
Bro...dah turun harga dah...menarik ni...
Ristoe
View user profile http://facebook.com/ristoe
Post by taj on Sat Oct 24, 2009 8:33 pm
yer la bro..mari2.....tu harga barang...pos tambah sikit la..
Post by ryiez on Thu Oct 29, 2009 3:27 pm
Da sirim punya cop ke x bro?
Material dia sama cam helmet besa ke..
ryiez
Post by taj on Thu Oct 29, 2009 5:46 pm
material ABS....bukan plastic..berat helmet dalam 1600gram
sirim takdak pasal ni buatan syarikat index thailand...mmg utk pasaran sana...kalau ada sirim pun berdasarkan pihak berkuasa thailand punya standard la....
boleh baca material ABS ni disini:
"Acrylonitrile butadiene styrene (ABS)
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Monomers in ABS polymer
ABS polymer grainsAcrylonitrile butadiene styrene (ABS) (chemical formula (C8H8)x· (C4H6)y·(C3H3N)z) is a common thermoplastic used to make light, rigid, molded products such as piping (for example plastic pressure pipe systems), musical instruments (most notably recorders and plastic clarinets), golf club heads (used for its good shock absorbance), automotive body parts, wheel covers, enclosures, protective headgear, buffer edging for furniture and joinery panels, Thule boxes, airsoft BBs and toys, including Lego bricks[1]. ABS plastic ground down to an average diameter of less than 1 micrometer is used as the colorant in some tattoo inks. Tattoo inks that use ABS are extremely vivid. This vividness is the most obvious indicator that the ink contains ABS, as tattoo inks rarely list their ingredients.[2]
It is a copolymer made by polymerizing styrene and acrylonitrile in the presence of polybutadiene. The proportions can vary from 15 to 35% acrylonitrile, 5 to 30% butadiene and 40 to 60% styrene. The result is a long chain of polybutadiene criss-crossed with shorter chains of poly(styrene-co-acrylonitrile). The nitrile groups from neighboring chains, being polar, attract each other and bind the chains together, making ABS stronger than pure polystyrene. The styrene gives the plastic a shiny, impervious surface. The butadiene, a rubbery substance, provides resilience even at low temperatures. For the majority of applications, ABS can be used between −25 and 60 °C as its mechanical properties vary with temperature. The properties are created by rubber toughening, where fine particles of elastomer are distributed throughout the rigid matrix.
Production of 1 kg of ABS requires the equivalent of about 2 kg of oil for raw materials and energy. It can also be recycled.[3]"
http://en.wikipedia.org/wiki/Acrylonitrile_butadiene_styrene
Post by arjuna86 on Thu Nov 05, 2009 8:21 am
salam.. bro.. kalo pos area sah alam agk2 brape?
arjuna86
Post by taj on Thu Nov 05, 2009 9:28 am
rm10 ja..
Post by JAZMI on Thu Nov 19, 2009 1:15 pm
bro, color len xdak dah ker...nak cari color merah la...ada x?
JAZMI
Post by taj on Thu Nov 19, 2009 3:10 pm
takda..yg ada kaler hitam metallic, hitam mati/kusam, putih,brown...
stock yg ada hitam la, putih dan brown nak kena cek dulu
bro nak warna apa?
kalau nak order pm saya
Post by muaz89 on Sun Dec 13, 2009 1:32 pm
bro aku nk satu
muaz89
Post by taj on Sun Dec 13, 2009 1:59 pm
buat payment then info nak warna apa...dalam seminggu dapat la helmet..PM aku kalau nak..atau sms aja..
Post by metz on Tue Dec 22, 2009 4:28 pm
taj..helmet ni ada pilihan saiz tak..cam saiz 'S','M','L' atau hanya ada saiz 'L' sahaja
metz
Post by taj on Tue Dec 22, 2009 5:18 pm
sori metz..kat siam nuuu..semua helmet saiz L..tak faham aku....
Post by metz on Tue Dec 22, 2009 5:43 pm
takpe la aku try muiz punya dulu..kalo ngam ingat nak angkat satu..warna putih tu....terliur aku
metz
Post by taj on Wed Dec 23, 2009 8:17 am
satu lagi cara kalau rasa longgar sikit..hang pakai la balaclava/buff/beans dan etc
tapi kalau longgar byk jgn pakai....bahaya...
by the way aku rasa saiz L dia kecik sikit dari biasa...aku pakai agak fir dan ketat kat kepala aku...walaupun aku pakai saiz L,,,,apap pun test dulu kat muiz
Post by myrad85 on Tue Jan 12, 2010 6:43 pm
ak dah order nih.... huhuhu Very Happy
myrad85
Post by budakdegilz on Fri Jan 15, 2010 2:25 am
barang sudah terima...TQ bro taj...!!
budakdegilz
Post by taj on Tue Jan 26, 2010 9:43 am
kalau dah terima harap dapat display la heheheh...
Post by heretichaze on Wed Feb 24, 2010 3:03 am
bro visor die xde yg jernih ke??bahaya klu riding mlm nih...
Post by taj on Wed Feb 24, 2010 8:42 am
ok ja...aku ride malam2 masih acceptable..
Post by arepeaceDNA on Thu Mar 11, 2010 11:42 pm
bro, klu order, brape hari amek masa nk smapai ye? ready stock or nk kena order dlu? brkana gak ni...tp kompius nk pilih kaler itam or putih....huhu
arepeaceDNA
Post by taj on Fri Mar 12, 2010 12:01 am
jangkamasa nak sampai kat bro dalam 3-4 hari la after payment...kalau boleh buat payment cepat saya boleh dapatkan dalam masa 2 hari then pos dalam sehari ja kat bro...guna skynet...
putih pun cun jugak nampak solid..tapi kalau nak plain dan nampak kecik sikit warna hitam la..
Post by arepeaceDNA on Fri Mar 12, 2010 12:09 am
sy ni bru je pkai fz...ingt nk usha2 fullface yg bru or 2nd, jnji ada sirim....tp bajet xbnyk la...~200 je...
ok x index ni bro? approve by DOT kn? org kata DOT x brape elok....
takot gak la...bkn takot kt jpj...tp syg nyawa...huhu
arepeaceDNA
Post by taj on Fri Mar 12, 2010 12:17 am
helmet index ni approve by thailand standard certification...
boleh rujuk sini:
http://www.indexhelmet.com/mainframe/indexframe.htm
Post by arepeaceDNA on Fri Mar 12, 2010 12:47 am
ok...pape nnti sy roger...
arepeaceDNA
