problem fz aku
+10
lurhaysR15
wahid alwie
ryman
dennis
14 posters
problem fz aku
salam bro taj,ni ak nk bgtw yg motr ak ade problem..
problem nye ialah,bile ak bwk laju jer..xkire la jauh ke dekt,bile ak free gear,tekan brek,rpm 0,tp enjin running
xpun plg best,enjim mati sndri..
ak g la cek kt yamaha,die ckp enjin coil rosak..
ok,ak pun tukar sbb ade warranty dgn AON,250 ak habis..tp covered.hehe..
lps tukr,ak testla,still prob jgak..bwk laju jer,rpm 0,enjin runng..
ak xde tmbah ape2 eksesori mcm alrm ke,ape ke..yg ade pun horn jela..
asal ek?ak kesian kt motr aku ni..syang kot..
ade idea knp jd mcm ni?
dennis- Posts : 42
Re: problem fz aku
Bateri baru x? Kalo bleh cuba tukar bateri plak @ pinjam bateri kwn2..
ryman- Posts : 42
Re: problem fz aku
bateri eh?ok2..nnti ak try adjust...
slain dr bateri ape ag?
dennis- Posts : 42
Re: problem fz aku
oh try tukar fius x? aku pon kena gak camtu.. pastu pegi pomen yamaha dia just tukar fius yg baru.. alhamdulillah setel.. harap membantu
radzi- Posts : 29
Re: problem fz aku
lampu ade sikit malap x bile tekan brek 2??
Hafiz7071- Posts : 89
Re: problem fz aku
coil dah tukar ok...then cek rectifier..then cek bateri....
yg pasang horn ada pasang relay tak?kalau silap pasang boleh kong bateri...
selalunya mcm bro ni sama ada coil, rectifier atau bateri...
fuel pump jugak boleh jadi punca tapi tak selalu, coil igniition pun boleh jadi...
Re: problem fz aku
radzi wrote:oh try tukar fius x? aku pon kena gak camtu.. pastu pegi pomen yamaha dia just tukar fius yg baru.. alhamdulillah setel.. harap membantu
bro radzi,fius ape yg nk kne tukar tu?ak xtaw..
dennis- Posts : 42
Re: problem fz aku
Hafiz7071 wrote:lampu ade sikit malap x bile tekan brek 2??
hafiz:ade2..memg bile tekn brek jer lampu malap skit..rpm 0..
dennis- Posts : 42
Re: problem fz aku
taj wrote:coil dah tukar ok...then cek rectifier..then cek bateri....
yg horn tu memg cine tu ad epsg relay len..nk bg support horn..
pastu pomen tmpt ak beli motor tu die bukak dulu horn aku,bg bateri cas lebih..
xtw la mcm ne...agk2 lebih elok truskn pkai horn tu or xyah?
dennis- Posts : 42
Re: problem fz aku
rectifire problem 2..tukar je
dlu aku pnah jadi gak..3 4 kali tukar bateri
tukar rectifire sume ok
Re: problem fz aku
fius tu ada dlm bekas kecil warna putih sebelah bateri jer.. tak besar mana pun fius tu.. macam fius kereta gak tapi moto kita pakai satu ja..
radzi- Posts : 29
Re: problem fz aku
Rsanya masa 1st mula kuar moto tu idle rpm rendah kot jd power tk ckup.normal rpm dlm 1500-1300rpm, lama2 batt leh out.sbb aritu pmen yamaha ada bgtau kt saya mcm tu.
Re: problem fz aku
owh..pttla motor aku time pns enjin tiap2 pg rpm xduduk diam..kejp naik,kejp trun..
agk2 nk cas bateri tu amek mase lame x?
dennis- Posts : 42
Re: problem fz aku
cabel meter rpm rosak 2 bro......
6p- Posts : 52
Re: problem fz aku
ehh... aku pun jadi camtu gak.. cuma enjin x mati... klu lepas naik motor, bile idle n tgh tekan brek, rpm jadi kosong & lampu jadi malap.... aku ingat bateri kut kena cas balik... kenaper ekkk...?? aku blum tukar pape lg nie... masih standard
x-wave100- Posts : 101
Re: problem fz aku
dah 3 tahun aku guna FZ ni.. ok jer.. xbyk problem.. cuma getah/plastik pemegang signal depan dah mereput.. mgkin hari2 packing tgh panas kot.. tajul ada jual ker getah tu?
wahid alwie- Posts : 4
Re: problem fz aku
x-wave100 wrote:ehh... aku pun jadi camtu gak.. cuma enjin x mati... klu lepas naik motor, bile idle n tgh tekan brek, rpm jadi kosong & lampu jadi malap.... aku ingat bateri kut kena cas balik... kenaper ekkk...?? aku blum tukar pape lg nie... masih standard
aku pun same cam ko dulu..xtau r sebab ape..tp bile membe aku(rechnician eletrik) die doh tukar fius bea seat 2 besar skt amp die..trus ilang problem 2..try la
Re: problem fz aku
Aku pun kne mcm tu.. Tukar bateri besar sikit trus ok
lurhaysR15- Posts : 595
Re: problem fz aku
bateri ape tu yg beasr? bateri lori ka? bateri tractor ka?lurhaysR15 wrote:Aku pun kne mcm tu.. Tukar bateri besar sikit trus ok
fritz_dust- Posts : 286
Re: problem fz aku
fritz_dust wrote:bateri ape tu yg beasr? bateri lori ka? bateri tractor ka?lurhaysR15 wrote:Aku pun kne mcm tu.. Tukar bateri besar sikit trus ok
aku rasa di sarankan pakai ler volt stabilizer...memang terjaga semua sistem elektrik di dalam motor efjek kita ni......
Red D'jango79- Posts : 108
Re: problem fz aku
Salam...problem fz aku plak bile rpm cecah 5000-7000 lampu meter kat rpm dok berkelip2x...kenapa ek? waranty still ade lagi...mileage baru 6k..
arituh ada p HLY sebab terkejut tgk air coolent kejap je tggal sikit (padahal mende ni normal) HLY topup free tp yg tak bestnye ada screw kat radiator belah kanan dia lupa kot nak pasang (apsal dia bukak radiator ?)..pastu boleh plak tak tutop tmpat isi air coolent tuh..nasib baik cek..
So skang rase risau plak nak p cek lampu meter rpm nih takot2x lampu moto fz plak dia lupa pasang..hehehhe
Ada pape cadangan tak? maaf saya budak baru pkai fz ni..tq
krizal- Posts : 17
Re: problem fz aku
krizal wrote:Salam...problem fz aku plak bile rpm cecah 5000-7000 lampu meter kat rpm dok berkelip2x...kenapa ek? waranty still ade lagi...mileage baru 6k..
>..w'salam..warranty mostly still valid kalau tak capai 10k km lagi (kalau tak silap la) so better pi check claim warranty daripada kena keluar kan duit sendiri..
>..problem motor aku macam2..ada yang kata bila kita tukar sesuatu akan ada effect pada motor:
-buat full fairing> sama je kelajuan
-tukar exhaust> sama je kelajuan
-tukar sprocket> sama je kelajuan
-tukar tayar dan rim lebar> sama je kelajuan
-tukar jenis EO> sama je kelajuan
>..hahaha motor aku tetap lembap gak kalau buat pape pun ..
>..baru2 ni meter atau pelampung dalam tank yg problem:
-paras mintak tak tentu, ikot suka hati dia nak naik atau turun, kadang2 turun sampai ketuk meter kurang dari E
-jarum tunjuk kt E, tapi isi minyak Ron 95 RM10 terus dapat full hahaha
>..lepas tu tukar handle hari tu, tiba2 dapat masalah ni:
-aku pakai handle switch, bila pada idle, lampu meter yang menyala hanya KM dan tengah tu, RPM tak menyala..
-meter minyak masih gelong..
~b0c3T~- Posts : 279
Re: problem fz aku
b0c3T..uik trus tak nyala lampu rpm ko. lg bnyk masalah yg tak kene....at least akunye nyala ala 2x kenyit bile merembat moto..ok2x.. nmpknye kene p skali lgla HLY ni...yup still ada waranty..kene wat cek semulala. Lpas anta kat sana..kang ade jek mende yg tak kene..dahla jauh nak ulang alik.
krizal- Posts : 17
Re: problem fz aku
baru balik dr HLY hari nih.. yesss...lampu meter rpm ku dah okey,katanye sebb aku pasang alarm, btol ke? padahal pkai alarm YAMAHA tuh..tp, soklan tentang screw radiator belah kanan tuh.. rupa2xnye kat situ mmg takda pon screw cam belah kiri radiator..adeh rase cam nak balik jek dat time.. tp terstop jap xjd balik sebb bro kat HLY tuh tetiba bg keychain yamaha...hehehe. nak p lagila sana mana tau dpt baju plak
krizal- Posts : 17
