6th gear set (5 piece item) rm500
+61
capix
redheart1989
docgabby
extreme
izzul hadi
SYAMIL
BaD a.k.a PaLi
pizdin
sham2716
lutfi
kcr9591
awateff
azri2ayie
KFZ
saqosz
mychak74
afiq
ridhwan91
yu_jaws
syah90
RinGGoStaR
TokBromoh87
LIONSTAR
zamakh
DeadSix
achid
aidarafi
dabel_farouqi
FireRider
ryman
defender
deva3535
andychankh
wanzikri
nik2121
yoshiki81
sapet
leo2979
303624
Zainiky3
ezad_agent47
~b0c3T~
mfy1985
kyunfz150i
trunks
SaLLeH
amin
en_iwan
kecohboy
disasterpiece
skankin
emmzet
65 posters
taj motoshop: fz150i services and accessories :: FZ150i Product @ Taj Motoshop :: YZF-R15 FULL FAIRING FOR FZ150i :: YZF R15 6TH GEAR SET
Page 3 of 10
Page 3 of 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: 6th gear set (5 piece item) rm500
klu maen sproket yg asal, 15-42..
bila msuk gear 6 jd bape ek gear ratio?
asal 5 gear bape ratio?
wanzikri wrote:klu maen sproket yg asal, 15-42..
turunkan jadi 14-42..
more pickup, more top...
tp kalau hang sarung bigbore, leh sapot kot 15-42 tu
nik2121- Posts : 60
[/quote]
tp kalau hang sarung bigbore, leh sapot kot 15-42 tu[/quote]
itu mcm da ikut r15,xpe ke ECU Fz kan mapping laen ngan r15
wanzikri wrote:
itu mcm da ikut r15,xpe ke ECU Fz kan mapping laen ngan r15[/quote]
mapping je laen..
gear ratio / primary ratio tetap sama..
nik2121- Posts : 60
itu untuk ignition ja...mapping tak kacau itu untuk cepat atau lambat ja...
mksd sy cmni bro taj, mapping ecu r15 utk lbh kpd high rpm kan(blh bg mnyk n api lbh), jd mmg ptut guna 6 gear sbb de lajak nk tarik dr gear 4,5 ke 6 tu kan?
klu kita msukkan gear 6 kat Fz, adakah cut off yg de kat ecu Fz tu bg efek slagi xtuka sproket ratio bg balance balik output,tork yg asal?
tu disarankan guna sproket setting mcm r15, 14-42, gear sama ja ratio dia...ecu ni untuk timing ignition...cutoff sama ja dgn r15 kat 10.5k rpm jugak...btw india sama climate dgn malaysia so mapping tak lari sgt unless mcm europe fiorangnya mapping agak rich sebab cuaca sejuk...ni untuk setting standard la....
senang mcm ni la...bro pernah bawak fz masa top speed tak..ada rasa mcm motor mintak gear lagi kan?TU MAKSUDNYA RATIO MASIH TINGGI MASA TOP SPEED....
lagipun berdasarkan pengalaman user dari seberang pakai gear 6 ni dgn setting standard boleh cecah 160kmj, so ok la tu....di indo setting sproket setting diorang standard 14-42..malaysia ja 15-42.kalau masa top speed pun dah rasa takder pickup dah maksudnya power motor fz tu ada masalahlah...
apa2 pun setiap motor ni kalau ada perubahan mmg kena test dulu..machine ni different mecahnical performance walaupun type sama...
kalau bro nak kaji lagi sila kaji lagi dan share detail kat sini...ok?
owh, itula jwpn yg dicari..huhu
btw tq so much bro taj sbb share d info, mmg sy tgh stadi lg ape yg trbaek nk msuk kat fz sy nnt. xmo pkai taruk je,xpsl2 rugi klu power xckup nk balance ngan sproket ratio
cut off x kacau pon... anyway... play with speed on now
review la sikit bro...racun semua reader yg tgh pasang angan2...hahah
xmo la... kl nak tau, pasang sendiri...
xpa2...
taj, gear 7 da ada blum? den nak jd orang pertama pasang..
muahahahaha
muahahahaha
nik2121- Posts : 60
aprillia pon ader pakai... terlambat apenye...
bukan ke mito je yg ada gear 7?
nik2121- Posts : 60
R1 pon ader 8 gear
ok... aku crite ckit la... tapi x test lagi atas highway... pada 140km/j pada meter rpm ada lebey kurang dlm 7.5-7.9k... so calculate yg aku boleh buat maybe dpt lebih drp 160km/j bergantung pada berat rider itu sendiri... dan kalau main dlm 80-100km/j, petrol mmg save giler... x penah2 aku dpt 1 isian penuh petrol over 340km... so, fikir2kanlah... berbaloi @ tidak pakai 6th gear nih... errrkkk.... ehmmm orait... sekian laporan aku... he he he
spoket 14-42 ke bro?
atau 15-42?
cam ada tukar?
blok 60mm kan?
atau 15-42?
cam ada tukar?
blok 60mm kan?
nik2121- Posts : 60
stendet kilang HLY semua la...
mantap .....speed 140kmj baru 8k?mmg berbaloi....huhuhuhu...160kmj mmg boleh cecah la nibuana07 wrote:ok... aku crite ckit la... tapi x test lagi atas highway... pada 140km/j pada meter rpm ada lebey kurang dlm 7.5-7.9k... so calculate yg aku boleh buat maybe dpt lebih drp 160km/j bergantung pada berat rider itu sendiri... dan kalau main dlm 80-100km/j, petrol mmg save giler... x penah2 aku dpt 1 isian penuh petrol over 340km... so, fikir2kanlah... berbaloi @ tidak pakai 6th gear nih... errrkkk.... ehmmm orait... sekian laporan aku... he he he
owh..
ok2..
leh wat rekod baru kt - kl ni
3 jam...
skarang ni rekod 4 jam...
muahahaha
ok2..
3 jam...
muahahaha
nik2121- Posts : 60
gelak sakan nik...hehehe
kita punya pun tak sampai lagi ni..menggeletar dah ni...heheh
» WTS 2nd hand fz item
» bajaj pulsar 220 rm500
» digital speedometer rm500
» ORIGINAL YAMAHA FZ150i SPORT RIM RM500
» YAMAHA FZ150i ORIGINAL CYLINDER FULL SET RM500
Page 3 of 10
